Date/Time: Wed, 18 Nov 2026 08:54:58 +0000
Study Summary Window
View Count: 930
| [2020-05-20 17:06:07] |
| RolandC - Posts: 54 |
HI I want to add the Study Summary window to a control bar, but when I try by opening Customise Control Bar window, it does not show as available under the File Menu even though I can see it under the file menu normally. Roland |
| [2020-05-20 22:31:58] |
Okay we need to add support for this. We will do that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-20 22:32:05
