Date/Time: Wed, 18 Nov 2026 08:55:09 +0000
[User Discussion] - NVOL Ratio, Can Sierra Do This?
View Count: 907
[2020-05-20 16:22:24]
Alberto Gauer - Posts: 121
Hi there.
In thinkorswim there is a study that shows the uvol/dvol ratio on the chart as a label.
This is the formula:
def UV = close("$UVOL");
def DV = close ("$DVOL");
def ADL = UV - DV;
def ADR = if UV > DV then UV / DV else -DV / UV;
input mode = {default Ratio, Issues};
def modeSwitch = if mode == mode.Ratio then 1 else 0;
AddChartLabel(yes, concat(
if modeSwitch then ADR else ADL, concat(" ",
if modeSwitch then ":1 NYSE UV/DV" else " NYSE UV/DV")),
if modeSwitch then if ADR > ADR[1] then color.green else color.red else if ADL > ADL[1] then color.green else color.red);
plot null = double.nan;
Can Sierra do this? .
Date Time Of Last Edit: 2020-05-20 16:24:41
