Date/Time: Wed, 18 Nov 2026 08:55:11 +0000
Can't fully right align volume by price
View Count: 1972
| [2020-05-20 04:32:24] |
| Ala - Posts: 8 |
Hello there, Trying to right align volume by price, have chosen to right align and to always display last profile within view, but I get this: https://prnt.sc/sk3hy4 If I keep scrolling, this is how far it has to go to settle and leave space between the profile and the bars: https://prnt.sc/sk3kcn On the other hand, if I squish the chart horizontally as much as possible, the vbp ends up hiding behind the price axis: https://prnt.sc/sk3kx3 Are the labels causing an issue for it not to go all the way to the right? How can I resolve this? I just want the VBP to stick to the right against the price axis, and to leave some gap between it and the bars. Thank you. |
| [2020-05-20 06:46:59] |
| Ala - Posts: 8 |
Ok I may have figured it out. When I changed background color I saw there was another profile (morning vbp) pushing the visible profile (overnight vbp) ahead, since both of them had the always display last profile within view. Is there anyway to have it so that only active session's VBP is the one that's always within view, or must I switch this setting as I enter different sessions?
| [2020-05-20 09:10:02] |
| User907968 - Posts: 887 |
Did you also set 'Align to Far Right'? Volume By Price Study: Align to Far Right |
