Date/Time: Wed, 18 Nov 2026 08:47:09 +0000
can't connect with Rithmic data feed
View Count: 895
[2020-05-18 16:29:58]
User578810 - Posts: 5
the login to Rithmic Trader works ok.
Rithmic Trading | Port for executable: 1559 | 2020-05-18 14:00:18.736
Listening socket (1756). Port 1559 | Closed. | 2020-05-18 14:00:18.736
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-05-18 14:00:18.737
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:1559. Current folder: C:\SierraChart\Rim | 2020-05-18 14:00:18.740
Rithmic Trading | Bridge process is not running! | 2020-05-18 14:00:20.736
Rithmic Trading | Connecting to the server 127.0.0.1. Port 1559 | 2020-05-18 14:00:20.736
DTC Client socket (1) | Creating socket. | 2020-05-18 14:00:20.736
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-05-18 14:00:20.736
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-05-18 14:00:22.738 *
DTC Client socket (1) | CloseSocket call. | 2020-05-18 14:00:22.738
DTC Client socket (1) | Closed. | 2020-05-18 14:00:22.738
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-05-18 14:00:22.738
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-18 14:00:22.738
DTC Client socket (0) | CloseSocket call. | 2020-05-18 14:00:22.753
Rithmic Trading | Disconnected. | 2020-05-18 14:00:22.753
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-05-18 14:00:22.753
[2020-05-18 17:40:07]
This log is incomplete but the reason is probably due to what is explained here with a change to connections by Rithmic:
Regarding Rithmic (Our Final Post on this Subject)
Date Time Of Last Edit: 2020-05-18 17:40:17
