Date/Time: Wed, 18 Nov 2026 08:46:45 +0000
Target and Stop Quantity Question
View Count: 1113
[2020-05-16 20:09:45]
User969241 - Posts: 155
I have checked the USE ATTACHED ORDERS on my chart trader window.
I set the quantity on the MAIN tab to 2.
When I set a STOP in TARGETS tab, I try to set it to 2 and set 2 separate targets to 1 quantity each. I want my STOP to be 2 units at the same price on entry. I want the targets to each be 1 unit at different prices. It says the Target/Stop doesn't match at 2 units. The quantity in target 1 is 1 unit and the quantity in target 2 is 2 units. The stop quantity is 2 units. When I try to switch target 2 to 1 unit, it automatically change the STOP target unit to 1. I need the STOP target unit to be at 2 and each TARGET unit to be at 1 so I can scale out of the position.
Thank you
[2020-05-17 07:00:13]
What you want is explained here:
Attached Orders: Multiple-Bracket Example
