Date/Time: Wed, 18 Nov 2026 08:46:47 +0000
[User Discussion] - Cannot Import Tick Data into Sierra Chart
View Count: 851
[2020-05-15 03:18:44]
Rparm - Posts: 5
I am trying to import the attached Data File ~2MB size (it is a small snippet of a larger file),
I am attempting to import using the following SC Menu item:
SC > EDIT > Import and Load Intraday Data
I always receive the following error:
Error reading Intraday text file to import. | 2020-05-14 19:58:03.462 *
I tried formatting the data as simple as possible (I removed volumes etc.) So now the Data looks as follows, I have even tried importing just the below 4 lines and it does import occasionally.
If I delete the .txt file and .scid file, and attempt to import again just the 4 lines below... SC sometimes imports it, but often displays the above error.
If I try and import several lines or more SC shows the above error 100% of the time.
Date, Time, Close
20090927, 183000, 118.0469
20090927, 183001, 118.0469
I have looked over the Importing Guide here at SC.com with no solution to this issue. Any help would be appreciated!
attachmenttest.txt - Attached On 2020-05-15 03:08:12 UTC - Size: 1.75 MB - 525 views
