Date/Time: Wed, 18 Nov 2026 08:47:08 +0000
[User Discussion] - Change all Symbols when loading new chartbook with different data
View Count: 1640
| [2020-05-13 11:17:19] |
| User181601 - Posts: 25 |
Hi, I am using Cqg data and symbols show as _ [Ex: for Spx500 = F.US.EPM20 ] I have now changed chartbook which has Ritmic data and symbols show in a different way [Ex: ESM20 ] and of course the charts are not displaying.. I am aware that i could change the symbol "One by one" or just link charts_ I reminded that there was also another way that i have simply forgotten as i don't charge Cht's with different data often. How to change all Chart-books symbol at once when loading a chartbook with different data > I did enable the "Support Symbol Entry from Chart Window" [Global Setting Settings>> General Settings>> General2(Tab)] but i guess there is more to do as it didn't work_ Thank you |
| [2020-05-13 12:07:17] |
What you are looking for is Edit >> Translate Symbols to Current Service.
| [2020-05-13 12:20:57] |
Aww I'll be Damned ! Thank you Sir, that was the one ... You guys are so much improving Sierra and it has so many beautiful/useful functions Thanks for your hard work_ |
