Date/Time: Wed, 18 Nov 2026 08:46:54 +0000
Feature Request: Use Symbol Based Chart Settings
View Count: 857
| [2020-05-11 14:02:11] |
| ticinotrader - Posts: 431 |
Dear Support, Can you please consider adding the possibility to store Chart and Study Settings on a per Symbol basis? I mean, a similar functionality that is already available for chart drawings: chart drawings are stored and can be displayed on the symbol where they were drawn but can be automatically hidden if the chart's symbol is changed. This would greatly help to reduce the number of simultaneously opened charts and chartbooks just to display the same charts based on different Chart Settings (session, timezone, vol multiplier, etc) related to Symbol specific settings. Can you please let me know if this is something you already considered or you alredy work on? Thank you. |
| [2020-05-12 05:34:27] |
There is no chance of any functionality being added beyond what Sierra Chart already has in this regard: This would greatly help to reduce the number of simultaneously opened charts and chartbooks just to display the same charts based on different Chart Settings (session, timezone, vol multiplier, etc) related to Symbol specific settings. This is already supported by setting the settings you require for individual specific symbols in the Global Settings >> Symbol Settings. You can add and modify symbols as required.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-12 05:35:16
| [2020-05-12 07:09:46] |
OK, got it. Can you please let me know if there is a possibility to set the Volume at Price Multiplier in the Symbol settings? I've checked the available settings but did not find it - although there are some related (?) settings that are not clarified in the documentation. Thank you. |
| [2020-05-12 07:36:16] |
Yes, we will get this into the next release.
