Date/Time: Wed, 18 Nov 2026 08:47:06 +0000
Graphics settings.
View Count: 1092
| [2020-05-10 02:15:48] |
| User696494 - Posts: 2 |
I have loaded my Greencharts on my new computer. After checking all settings for Windows, Im looking for the settings In the Sierra platform that controls making the numbers and value labels larger. The charting is clear, but all alpha/ numeric is unreadable. Any assistance please? Thank you! |
| [2020-05-10 02:58:09] |
| User75002 - Posts: 117 |
Try this. Use the Global Settings | Graphics Settings to apply to all charts. Graphics Settings: Chart Text |
| [2020-05-11 14:30:52] |
Thank you! This was very helpful..... Though all the font setting were found for the platform Graphics in the Global Settings. I then realized what I needed enlarged were a part of the "CHART" settings. So I found the Chart Graphics under the Chart, Graphics settings. A perfect solution. I hope this helps someone else..
| [2020-05-11 21:15:00] |
Just be aware of the difference between Chart specific Graphics Settings and the Global Graphics Settings. Refer to the information here: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
