Date/Time: Wed, 18 Nov 2026 08:46:46 +0000
TPO Study & IBR Extensions chart label color inconsistency
View Count: 1105
[2020-05-09 02:11:13]
Using SC Since 2020 - Posts: 150
I've noticed a coloring inconsistency in IBR extension line labels where the label does not match the line color in the case of the 2nd color selection for the lower IBR extension lines. It appears the label always takes the first of the two colors in: TPO > Settings > Subgraphs > IBR Extension 1 Line...etc > Color. It's just a visual ugly/aesthetic, not a major thing. See screenshots.
imageTPO chart showing miscolored labels.png / V - Attached On 2020-05-09 02:07:44 UTC - Size: 52.27 KB - 425 views
imageTPO subgraph IBR settings.png / V - Attached On 2020-05-09 02:07:48 UTC - Size: 72.54 KB - 418 views
[2020-05-10 07:47:03]
We will look into this.
[2020-05-11 22:51:40]
Jeffrey - Posts: 2445
This should be fixed in the next release. Thank you for the detailed report.
Date Time Of Last Edit: 2020-05-11 22:52:19
