Date/Time: Wed, 18 Nov 2026 08:47:08 +0000
TPO Market profile
View Count: 1147
| [2020-05-08 16:49:57] |
| User756395 - Posts: 5 |
Whenever i switch a symbol on my TPO chart, the new chart includes merged profiles from the previous symbol, how do i stop that ? I want a separate TPO profile for each symbol.
| [2020-05-08 19:51:49] |
What you are stating is happening is proper functioning of the system. Splits and merges are not cleared on a symbol change. The only option would be to have 2 different charts and use the one where you do not merge the profiles to switch between symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-08 19:52:22
