Date/Time: Wed, 18 Nov 2026 08:55:14 +0000
export NQ trades
View Count: 1036
| [2020-05-06 16:27:59] |
| User843333 - Posts: 14 |
If I export my NQ trades using File > Export then I got a file with a filled at a strange price Filled 902400.0000000 and if I simply click File > Save then I got a file containing Filled 9024.00 this Is normal or it's an error? thx |
| [2020-05-06 20:22:11] |
Yes that is the unadjusted price format. If you want to have the adjusted price format you need to use the instructions here: Trade Activity Log: Saving to a Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-06 20:22:23
