Date/Time: Wed, 18 Nov 2026 08:54:58 +0000
how to setup
View Count: 896
| [2020-05-04 15:57:36] |
| User965966 - Posts: 1 |
Hi I am currently customer of sierra chart AC89152 useing cqg from amp clearing broker, now I am also try to setup second account with rothmic direct from GFF broker so how to setup Sierra chart on second account, can I login both account at same time, do I need to pay for both account, if can you please send me info how to setup. Thanks Kirti Date Time Of Last Edit: 2020-05-05 08:29:01
| [2020-05-05 11:39:20] |
You do need to use your own direct account for the other broker(GFF). Refer to: Direct Sierra Chart Account All you need is just this one Sierra Chart account. You can install two copies of Sierra Chart and be logged into both: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
