Date/Time: Sat, 31 Oct 2026 18:08:01 +0000
The Chartbook file requires a newer version of Sierra Chart or is not a valid . File: C:\S
View Count: 1178
[2020-04-30 14:32:35]
gregm - Posts: 4
The Chartbook file requires a newer version of Sierra Chart or is not a valid . File: C:\SierraChart\Data\ES.cht | 2020-04-30 10:28:33.989 *
I am getting this message for all my charts
I did download the most current version
[2020-04-30 17:56:02]
You may have updated to the prerelease and then went back to a prior version.
Select File >> Open Chartbook. Do you see any chartbooks that have backup2092 in the name? If so, those are the ones you want to open. More information is in this thread here:
Version 2093: New Chartbook Format, Better Data Management in Sub Instances, Other
Date Time Of Last Edit: 2020-04-30 18:38:57
[2022-03-23 18:14:59]
User885199 - Posts: 1
I'm unable to use imported chartbooks/templates. I've tried installing different versions of the Software but they still won't work. See below for error message:
Reading Internal Order ID file. | 2022-03-23 13:04:39.190
Reading Trade Orders file. | 2022-03-23 13:04:39.320
Reading Trade Positions file. | 2022-03-23 13:04:39.320
Reading Trade Account Data files. | 2022-03-23 13:04:39.320
Software version: 2374 64-bit | 2022-03-23 13:04:39.350
Primary Thread ID: 17936 | 2022-03-23 13:04:39.350
Usage end date: 2022-09-18 | 2022-03-23 13:04:39.350
Enabled for: Advanced Features 2. | 2022-03-23 13:04:39.350
Enabled for: Sierra Chart Historical Data Service. | 2022-03-23 13:04:39.350
Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-23 13:04:39.350
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-23 13:04:39.350
Current selected Data/Trading service: SC Data - All Services | 2022-03-23 13:04:39.350
Custom symbol settings values: enabled | 2022-03-23 13:04:39.350
Chart Update Interval: 500 | 2022-03-23 13:04:39.350
Intraday Data Storage Time Unit: 0 | 2022-03-23 13:04:39.350
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-03-23 13:04:39.350
2022-03-23 18:04:39 Local computer time in UTC | 2022-03-23 13:04:39.350
2022-03-23 13:04:39 Local computer time in SC Time Zone | 2022-03-23 13:04:39.350
2022-03-23 18:04:38 Server time in UTC | 2022-03-23 13:04:39.350
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-03-23 13:04:39.350
Program path: C:\SierraChart\ | 2022-03-23 13:04:39.350
Data Files path: C:\SierraChart\Data\ | 2022-03-23 13:04:39.350
OS Version Number: 10.0 | 2022-03-23 13:04:39.350
Locale Setting: C | 2022-03-23 13:04:39.350
DLLs: UserContributedStudies_64.dll | 2022-03-23 13:04:39.350
Allowed protected custom studies: | 2022-03-23 13:04:39.350
Crash reporter started: true | 2022-03-23 13:04:39.350
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2022-03-23 13:04:39.381
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-03-23 13:04:39.408
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-03-23 13:04:39.552
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-03-23 13:04:39.552
Received 5 login tokens. | 2022-03-23 13:04:39.837
Symbol settings MD5 received. Request ID: 1. | 2022-03-23 13:04:41.576
Symbol settings are up-to-date for scdataallservices. | 2022-03-23 13:04:41.576
SC Data - All Services | Connected to server complete. | 2022-03-23 13:04:46.036
Triggering next historical data download in queue. | 2022-03-23 13:04:46.036
No download requests in the queue to start downloads for. | 2022-03-23 13:04:46.043
The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\ChartbookGroups\ES.cht | 2022-03-23 13:05:19.496 *
The Chartbook file is not a valid Chartbook. File: C:\SierraChart\Data\ChartbookGroups\ES.cht | 2022-03-23 13:09:20.483 *
[2022-03-23 19:58:47]
Refer to the documentation here regarding this:
Chartbooks (Workspaces): Opening Older Chartbooks
