Date/Time: Wed, 18 Nov 2026 09:17:04 +0000
Sierra Chart/AMP Account
View Count: 1401
| [2020-04-24 23:59:02] |
| User143891 - Posts: 3 |
I first started in Februari a direct Sierra account, then when I started the trading account with AMP, the link/connection between AMP and Sierra didn't work very well. Therefore, I changed the set up of the AMP platform and I choose the option "Datafeed option" Sierra Chart - TT-W(fix) -$20 per month (SC-Denali EXCHANGE DataFeed) +0.10 per contrat for direct billing of the Sierra Chart fees and Market fees from my AMP Account. The Real Time Data that I need are : EUREX CBOT It's seems that the Sierra Chart software and the AMP Account are stil not working correctly .Could you please fix the problem and organize the login setup with your collegue of AMP Future. Thanks Regards |
| [2020-04-25 07:48:27] |
Since you need EUREX at this time, we just recommend using CQG for the data and trading: CQG Trading Platform Service We will have a good complete EUREX solution soon with our order routing service but not yet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-25 07:48:46
