Date/Time: Wed, 18 Nov 2026 09:17:10 +0000
VOL PROFIL SC3 or SC5
View Count: 744
| [2020-04-24 11:31:54] |
| User766588 - Posts: 20 |
MY VERSION is SC 3. Sc3 allows : 1)to set VOL PROF AS FOR ATTACHED chart N 1( SIERRA ORIGINAL) 2) AND VP SETTING AS ATTACHED N 2 ( TSNIPER SIMILAR ) h1 time frame ? thanks you umberto p |
| [2020-04-24 18:54:13] |
We are not understanding this.
