Date/Time: Wed, 18 Nov 2026 08:54:53 +0000
changes in toolbars
View Count: 1228
| [2020-04-23 15:03:06] |
| EuropeanTrader - Posts: 290 |
Hi, how can I have my old way of showing the toolbar functions as icons, please? Pic attached. It keeps reverting back to text with each upgrade. Thanks. |
| [2020-04-23 21:05:03] |
Refer to the notes here for version 2065: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-23 21:05:32
| [2020-04-24 19:08:35] |
| User65931 - Posts: 28 |
Could you also make the sierra chart icons larger?
| [2020-04-24 19:11:53] |
We do not know what icons you are referring to.
| [2020-04-24 19:27:46] |
Global Settings --> Customize Control Bars --> Properties --> Use image (Thank you for your tremendous work) |
| [2020-04-25 00:43:33] |
This is why we started using text for Drawing Tools because those are much easier to scale larger or smaller rather than images. Images really have to be re-created at different resolutions. So we do not have any short-term plans to re-create the Drawing Tool icons with a higher resolution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-25 00:43:39
