Date/Time: Mon, 28 Sep 2026 19:29:03 +0000
Unintentional reverse order sending just for YM Symbol
View Count: 1277
| [2014-01-15 17:09:59] |
it automatically says I'm in a reverse position and puts out my attached stop on that order. We do not understand this. Are you saying that the Position displayed on the Trade Window for the chart or Trade DOM is not correct? I flatten then the original closed P/L shows and trade activity shows just the original order. The Trade Activity tab of the Trade >> Trade Activity Log will show all order activity for the selected symbol.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-01-15 18:30:23] |
Are you referring to the Trade Stats for Charts tab? Or the Positions tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-15 18:32:59
