Date/Time: Wed, 18 Nov 2026 09:27:06 +0000
Instrument A and Instrument B
View Count: 795
| [2020-04-16 15:22:04] |
| User837393 - Posts: 161 |
Hello, In the same chartbook is it possible to have let say : Intraday chart of instrument A Intraday chart of instrument B And place trade only on instrument B, while having intrument A locked for trading or just trading disable for that instrument. Note : I call an instrument a Futur contract. |
| [2020-04-16 15:53:35] |
| John - SC Support - Posts: 48568 |
Yes, just use the Add Additional Symbol study. You will not be able to trade the symbol that is used in the Add Additional Study. Refer to the information here: Add Additional Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-16 19:50:13] |
You might be interested in this setting: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) It is not possible to lock trading for a particular symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
