Date/Time: Wed, 30 Sep 2026 08:20:33 +0000
Regarding Daily Range Bands Study
View Count: 1007
| [2020-04-10 13:19:08] |
| User38606 - Posts: 108 |
Quick question here: I have setup a Daily Range Bands Study which is based on 5day ADR calculated from Daily Chart. I want Upper Range Band and Lower Range Band to be fixed! In other words even if the price hits one of those.....the bands should stay there where they used to be. For some reason with the price reaching the band, the bands start adjusting and kind of stairing up/down - which I don't want to happen. What is wrong with my settings? For: Stop Updating High/Low When projected range met - I have YES. Is that what i need to do? Thank u consulting. I attached screen of my setup for yr ref. |
| [2020-04-13 19:19:11] |
We are not sure about this unless we test this set up. We would need to get a Chartbook from you containing both of those charts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-13 19:19:17
