Date/Time: Wed, 30 Sep 2026 09:19:54 +0000
order routing
View Count: 1084
| [2020-04-10 02:43:22] |
| User843333 - Posts: 14 |
Hi, 1. I have activated into my account "Sierrachart data feed". In order to use Sierrachart order routing with TT Fix it is a must to use Denali data feed? or I can use also "Sierrachart data feed" ? 2. If I will use only Denali exchange data feed, for using Bitmex Trading Direct, I will not have data feed for trading bitcoin XBTUSD-BMEX ? for trading on CME group exchanges with SC order routing TT Fix AND also using Bitmex do I need BOTH "Sierrachart data feed" + "Denali exchange data feed"? thx |
| [2020-04-11 01:07:43] |
1. You can use either for now but once one of the CME group related exchanges expires when using the Sierra Chart Exchange Data Feed, you can then only access the CME group data through the Denali Exchange Data Feed. 2. What you want to do is set up a separate installation of Sierra Chart to trade BitMex. Refer to: Using Multiple Data and Trading Services at the Same Time So you will have one installation for trading with the Sierra Chart Order Routing Service and another installation for BitMex. do I need BOTH "Sierrachart data feed" + "Denali exchange data feed"? No.
