Date/Time: Wed, 30 Sep 2026 09:19:33 +0000
US equities
View Count: 874
| [2020-04-08 16:55:46] |
| User261378 - Posts: 2 |
Hello, I have used Sierra Charts with U.S. Equities (NYSE, NASDAQ, AMEX, BATS) only for charting. I plan using Sierra Charts only for "replay charts" feature for U.S. Equities (NYSE, NASDAQ, AMEX, BATS) so no real time data is needed. Can not find information if "Standard" package is enough to use "replay chart" or I need to order extra data or connection package? Thank you |
| [2020-04-08 19:02:25] |
Yes the standard package is sufficient. It includes this service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
