Date/Time: Wed, 30 Sep 2026 10:14:48 +0000
Line of Close tool on toolbar?
View Count: 845
| [2020-04-03 17:29:41] |
| User72436 - Posts: 10 |
Is there any way that I can have a LOC or line on close tool on toolbar so that I can quickly toggle between Candle stick bars and Line on Close--without having to do it through chart settings each time? Thanks |
| [2020-04-03 19:06:54] |
Yes, just use the Customize Control Bar and add the options for each of the Bar Types that you want. Refer to the information here: Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
