Date/Time: Tue, 10 Nov 2026 08:21:10 +0000
Bitmex DTS - additional execInst
View Count: 1211
[2020-04-03 07:17:53]
User813500 - Posts: 8
hi, whats the correct syntax for "Additional execInst" when using SC BitmexDTS? I keep recieving the "unexpected token" error with stop orders.
Where can I find a full list of commands to be specified?
TY
version : SC 2068 service package5
[2020-04-03 09:53:18]
You will find the specific text strings to use in the BitMex API documentation on the BitMex website.
[2020-04-03 10:24:45]
Yes but I still recieve unexpected token error,
for example when I input: FillOrKill into Sierra DTS(additional execInst) the SC trade activity log returns with :
Order  2020-04-03 12:07:53.351  XBTUSD-BMEX  XBTUSD-BMEX[M] 10 Min #3 | User order entry | Last: 6970.5  8540    Stop  1  Buy  6900.0    Order Sent      [deletedAccNo]  Open    1441        Petka v procentu.twconfig
Order  2020-04-03 12:07:53.589  XBTUSD-BMEX  New order rejected - BitMEX Trading Direct error: Unexpected token F in JSON at position 137  8540    Stop  1  Buy  6900.0    Error      [deletedAccNo] Open    1441        Petka v procentu.twconfig
--------- THE log has been modified to exclude my account number.
I will find API commands myself but I still require your help with correct syntax. I am not a programmer myself.
[2020-04-04 11:19:31]
We do not think that is a valid Execution instruction . Instead it is a Time in Force. You can select that within Sierra Chart through the Trade Window:
Basic Trading and the Trade Window: Main >> TimeInForce (Time in Force):
[2020-06-16 09:22:38]
Yes you are right, it was not a valid instruction. Apologies for taking up unnecessary time.
