Date/Time: Wed, 30 Sep 2026 10:16:37 +0000
interactive support
View Count: 808
| [2020-04-01 17:56:35] |
| User457885 - Posts: 3 |
hello would like to set up interactive support,, asap,,, been trying to connect delani data ,thank you
| [2020-04-01 19:18:58] |
Did you want to pay for the Denali Exchange Data Feed directly yourself? Instead of through your trading account with AMP. That will be the easiest way.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-01 19:19:13
