Date/Time: Mon, 29 Apr 2024 14:56:50 +0000
CQG data for crude CL has only 400/400 levels + SWITCH TO DENALI
View Count: 1439
[2020-04-01 08:52:42] |
Also, you are able to restrict Market Depth to the number of levels that you want: Refer to 5 and 6 here: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-01 12:43:15] |
User311344 - Posts: 136 |
No it is not counted this way. It is 800 each side. And really at this point we can make that anything. We could make it 5000. We can then say we have got 5000 levels of depth. It is meaningless because 5000 levels do not even exist. We just found that 800 was more than sufficient.
We should probably make the number 1000 and just say there is full depth. We should not even be mentioning a number any longer. Hey, Im glad this 480 capping is being sorted out, but per what you said above, please take a look at enclosed chart showing historical number of levels for ES. As you can see Ask side often reaches 800 levels and is being cut off. So if theres no problem for you to make the number of available levels higher, could you make it so it would surelly contain all available depth from the exchange? 1500 levels per side would be a really reasonable value. Thanks in advance! |
cappedAt800.jpg / V - Attached On 2020-04-01 12:43:02 UTC - Size: 88.36 KB - 271 views |
[2020-04-02 20:00:31] |
User136422 - Posts: 33 |
Thank you for removing the 480 cap. Watched CL and ES depth last 2 days, CL has been cut off only one time, today at 10:34. Unfortunately ES depth is always severely cut off since the 800 cap is too small for the huge liquidity of the instrument, making the depth not very usable; as said by the user above increasing levels per side would be a great enhancement. Let us know if you need further information. As a said note, thank you for all the hard work on the feed, i was skeptical about Denali, but due all this improvements (implied depth, adding levels of depths, etc etc) is definitly becoming the best retail feed available on the market. Thanks |
crude sierra.jpg / V - Attached On 2020-04-02 19:58:42 UTC - Size: 124.89 KB - 274 views es sierra.jpg / V - Attached On 2020-04-02 19:58:50 UTC - Size: 141.75 KB - 264 views |
[2020-04-03 10:49:45] |
Yes we can increase it, but due to the method of market depth data management, which involves the client and server side, all users will need to update when we increase it. Otherwise there could be some unusual problems at the bottom of the depth for users who do not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-03 10:50:08
[2020-04-03 19:37:08] |
Oh thats great news!!! We're so looking forward to it!!!! |
