Date/Time: Fri, 02 Oct 2026 14:16:28 +0000
Spreadsheets and Studies - Cross-Referencing
View Count: 824
[2020-03-27 20:57:40]
a Gem Tree - Posts: 60
This is not necessarily a support issue. I understand what that means.
This is a spreadsheet coding issue - involving the use of the cumulative sum study.
--I have created an spreadsheet which outputs data to column X.
--Cumulative sum study then adds all of the data in column X, and creates the summed up data in column Y.
--Then I alter the data in column Y again, yielding column Z.
--Then I create Moving Averages of this summed up data, and reference the MAs using color bars.
Currently when I alter the original equation which creates column X, changes are not loading correctly into the MAs. As I change parts of the formula for column X - the MAs repeatedly do not change OR they have different results for the same input data (after being changed a few times).
Am I making a mistake by referencing a spreadsheet column, into a cumulative sum study, and back into the spreadsheet? That is my only guess...
I must use this cumulative sum study. Is there a way to sum up bars in spreadsheets that doesn't involve using the SUM function? (that annihilates my processor speed)
Seriously, any help is much appreciated.
Thank you.
