Date/Time: Sun, 04 Oct 2026 17:40:20 +0000
How to transfer SC settings to a new computer?
View Count: 2052
| [2020-03-27 11:52:24] |
| User755650 - Posts: 14 |
Hello, In the past I have copied the whole Data folder but in this case I would like to transfer only the Study Window settings, the Chart Settings and Chartbooks without the price data which is huge. |
| [2020-03-27 12:04:56] |
| User75002 - Posts: 117 |
Check this page: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation |
| [2020-03-27 17:47:58] |
In this case you just need to copy the Chartbook files (CHT file extension) which are contained within the Data Files Folder.
