Date/Time: Sun, 04 Oct 2026 17:40:18 +0000
Difference between DOM print and chart print
View Count: 879
| [2020-03-27 09:35:39] |
| User428450 - Posts: 5 |
Is there a way to display the lag between (difference) DOM print and chart print? See attached example - it can be price or time of print. I use TransAct/Infinity DOM and Sierra for charts. Is there a way to display the lag (price or time) between the TransAct/Infinty DOM print and the SierraChart print on the chart? With a display format like the Candle countdown timer. |
Attachment Deleted. |
