Date/Time: Sun, 04 Oct 2026 17:40:05 +0000
[User Discussion] - Study/Price Overlay
View Count: 967
| [2020-03-26 19:03:58] |
| User87521 - Posts: 116 |
I have something odd that I am hoping you can tell me is a setting somewhere. I have two chartbooks. Both are showing the same issue in real time, but never in backtesting. Both chartbooks utilize Spreadsheet System for Trading and Study/Price Overlay. I have attached imaging showing the issue. In the Offset Timeframe chartbook the Spreadsheet System for Trading Study is tracking a 60 min. chart of ES. for the main chart of MES which is a 5 min. chart. There should be 12 data inputs maximum for spreadsheet column AA. This isn't the case and the current study always goes longer than 12 before it switches the data set down and starts new again. I have observed that Column AA goes to 17 data points before it switches the data down and starts posting new data points. The same issue is appearing on the Amazon Offset chartbook. This is a 65 min. chrt. vs a 5 min. chart and should max out at 13 data points. Column AA appeared to flip to the proper setting after 19 data points. This does not change if I close the chartbook and re-open. It only occurs in real time. It appears to produce a delay in my real time trade execution. Thanks. |
| [2020-03-26 19:16:33] |
Image captures
| [2020-03-26 19:16:58] |
One more.
