Date/Time: Sun, 04 Oct 2026 16:26:24 +0000
CTS T4 with Sierra is off
View Count: 928
| [2020-03-20 06:54:01] |
| User569257 - Posts: 10 |
Hello, yesterday my CTS T4 Live Trading connection with Sierra Charts was simply switched off by the Broker without warning. Will this not be available in the future? Simulated Order and Sim Datafeed still available best regards, |
| [2020-03-20 10:50:56] |
This is odd because AMP told us they will give you notice that you have to change to another backend trading system before the end of the month. AMP is discontinuing support for CTS because there are just too few users on it. The two alternative choices you have would be the Sierra Chart Order Routing Service or CQG. Both are documented here: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-03-20 12:33:22] |
thanks for the News
