Date/Time: Sun, 04 Oct 2026 16:25:01 +0000
Problems with Rithmic
View Count: 894
[2020-03-19 19:08:15]
User730311 - Posts: 1
Dear Support Team,
I have a problem with the connectivity to Rithmic. The message is: "Rithmic bridge needs installing".This problem is new. The current sierra chart version is installed.
How can I solve this problem?
Thanks.
imagesierrechart_error.PNG / V - Attached On 2020-03-19 19:03:02 UTC - Size: 9.12 KB - 320 views
[2020-03-19 20:33:22]
Re-install the current version but on the Installation Window be sure to select the option for Install Optional Components.
