Date/Time: Sun, 27 Sep 2026 18:50:32 +0000
Chart right side vertical numbers increment
View Count: 1037
| [2020-03-18 16:35:35] |
| BenjFlame - Posts: 353 |
Hello, is there a way to control the increment between the vertical numbers on the right of the chart? This is not really a scale issue, I don' want to change scale of the chart but just the numbers. I set the grid vertical increment to 0.50, but numbers on the scale don't match as I would have expected, which creates confusion when a line is at let's say 15.50, but the nearest scale number is 15.40. |
| [2020-03-18 18:15:53] |
| User907968 - Posts: 884 |
Scale Increment Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) |
| [2020-03-18 18:34:17] |
Yes you need to use the Scale Increment setting in the Scale settings. Documentation link: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
