Date/Time: Sun, 04 Oct 2026 16:28:20 +0000
global cursor
View Count: 802
| [2020-03-17 15:43:48] |
| stephane1 - Posts: 112 |
hi is it possible to have same time the global cursor on DOM and chart ? regards SR |
| [2020-03-17 18:48:00] |
No, you cannot have the Chart Values tool on a Trading DOM, as there are not any bars on the Trading DOM.
