Date/Time: Wed, 04 Nov 2026 15:53:02 +0000
Stacked Imbalance - Extend until intersection
View Count: 6389
| [2020-03-16 20:07:40] |
| User135370 - Posts: 162 |
Hi I followed the documentation which was pretty easy to ready for the Volume Threshold V2 study. Thank you. In the instructions it said there is a way to extend the stacked imbalances as horizontal lines, is this possible? I have attached an image but I'm sure you know what I mean. Currently I get the yellow box to the left of the bar but would like a zone to be highlighted until intersection? |
| [2020-03-17 15:01:22] |
| John - SC Support - Posts: 48419 |
There is not a way to draw the extension lines for just the Stacked Imbalance. You can draw extension lines for each Volume at Price Threshold Alert. Just set the Input for Draw Extension Lines to Yes on the study settings. Refer to the information on the Inputs for the study here: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-08 03:49:57] |
| Sudhirc - Posts: 58 |
can you consider updating Volume at Price Threshold Alert V2 indicator to draw extension lines for just Stacked Imbalances. I'm sure a lot of them would appreciate it. http://www.sierrachart.com/image.php?Image=1596854765917.png |
| [2020-08-12 16:24:36] |
| User118316 - Posts: 1 |
Please, I need it too.
| [2020-08-13 02:37:35] |
| User372626 - Posts: 59 |
Any good samaritan with a coad? Three sets of unbalanced stack coade in a row ,thank you.
| [2020-08-13 16:22:58] |
| binaryduke - Posts: 387 |
Or if you see value in this you could purchase any of the commercial implementations of this.
| [2020-08-18 19:13:25] |
We have added the capability to draw extension lines until future intersection for the Adjacent Alerts (Stacked Imbalance). This will be in the next Pre-Release (v 2155). We changed the Draw Extension Lines Input to allow a selection of what you want to draw, which includes options for the top, buttom, or all of the adjacent alerts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-23 09:21:32] |
Thank you so much for this update, much appreciated. :-) Love you guys.
| [2020-09-18 14:30:24] |
| wallstreetsson - Posts: 80 |
sorry to ask, but how can i set this up? Cant find the Option for that!? "We changed the Draw Extension Lines Input to allow a selection of what you want to draw, which includes options for the top, buttom, or all of the adjacent alerts." Best Regards! |
| [2020-09-18 14:42:44] |
User103448 - You need to update to the current release in order to get this option. This change was made in version 2156.
| [2021-01-11 13:17:30] |
| User61576 - Posts: 458 |
is there any help to explain how to implement this?
| [2021-01-11 17:11:36] |
This is explained in the section for Draw Extension Lines under the Inputs section on this page: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-11 18:02:54] |
I checked it and it looks like working but it's not aligned with the #s bars pls check screen shot attached the yellow #s bars are imbalances and both studies are set to 300% (in #s bars it's 0,0,3) so how come some extend of the areas are not the same? |
| [2021-01-11 18:41:27] |
It is hard for us to say exactly the issue, as we can't see all the numbers, but in general the things to consider are the following: - The Percentage Threshold is only going to be used if the "Comparison Method" is set to a Ratio/Percentage. Otherwise, it is going to use the Volume Threshold. - The Threshold is only going to be for one side, as the calculation is only done in one direction. Therefore, in this case, you are only going to get an alert when the Ask/Bid ratio is greater than 300%, therefore the Ask must be greater than the Bid. In order to get the alert when the Bid is greater than the Ask, you would enter a -300. This is explained in the Percentage Threshold Input description: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-11 19:36:28] |
thanks. it helped after I created 2 separate studies (300/-300) |
