Date/Time: Sun, 04 Oct 2026 16:27:21 +0000
ACSIL: scAddAndManageSingleTextDrawingForStudy
View Count: 1840
| [2020-03-16 13:39:16] |
| User92573 - Posts: 617 |
Dear support I've read through: ACSIL Interface Members - Functions: sc.AddAndManageSingleTextDrawingForStudy() and the four associated support board requests but would be grateful for a short reply on the following which is not related. I'm currently using the tool as recommended but I'm struggling to control Bold text. It's a variation on the "Text Display For Study" found in studies3 with a single label per instance of the study. There are 7 parameters currently in this function and no way to control it there. Is there another way to set Bold = False using the "Text Display For Study" as the reference study? Many thanks |
| [2020-03-17 04:20:42] |
I'm currently using the tool as recommended but I'm struggling to control Bold text. We have to add a parameter to support this. It currently does not exist. This will be out in the next release.
| [2020-03-17 11:30:29] |
On reading through the documentation again as well as the Realtime Clock code (Studies2) and Visual Studio's intellisense that there are more parameters associated with the function scAddAndManageSingleTextDrawingForStudy than are used in the example "Text Display For Study" study. I can now see from the other parameters that there is already an option to use Bold .. or that its been recently added. Many thanks. |
| [2020-03-17 18:57:39] |
It has been added but not released.
