Date/Time: Sun, 04 Oct 2026 15:17:17 +0000
control bar issue after update
View Count: 792
| [2020-03-12 10:16:06] |
| User884550 - Posts: 149 |
icons gone from toolbar, displaying text instead, how to fix that? |
| [2020-03-12 18:05:18] |
That is because those images are older and they look too small on 4K monitors. However, you can still use them if you follow the instructions here: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
