Date/Time: Sun, 04 Oct 2026 14:19:52 +0000
Technical Notice: After January 15, 2020 Sierra no 32 bit version: drops support for macOS
View Count: 811
| [2020-03-06 11:27:20] |
| Mack - Posts: 83 |
Hi SC Engineering, I'm not a 100% sure if you are aware that running the 32 bit version, is right now the only way for macOS users to get the latest version of SierraChart. The 64 bit version runs into problems with Wine 5.0 on macOS. See more here: - SC version 2022 and later crash under wine64 on OSX, while SC version 2021 runs fine In the screenshot attached below, you can see that macOS can still run the latest builds, but only if you select the 32 bit version of Sierra. Date Time Of Last Edit: 2020-03-06 17:26:14
Attachment Deleted. |
| [2020-03-06 17:45:29] |
Okay, thank you for the information. We can maintain the 32-bit version for now. We actually have not withdrawn it. The latest version still provides the 32-bit version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-06 17:45:35
