Date/Time: Sun, 04 Oct 2026 13:21:24 +0000
SC instances - same machine - it is over babe
View Count: 754
| [2020-03-02 18:56:22] |
| User12089 - Posts: 386 |
yet another observation - SC Data Feed started counting EACH SC instance EVEN WHEN ON THE SAME MACHINE, as a "separate" data connection - that is the END of the SC scalability, since SC is a single threaded application and the ONLY way to paralelise it to make use of the multiple CPU cores available on modern machines, was to run multiple SC instances on the same machine
Date Time Of Last Edit: 2020-03-02 18:56:50
| [2020-03-02 19:10:31] |
This is nothing new. This is a restriction placed by Barchart who is the vendor of record. This has always existed. And also Sierra Chart is not single threaded. And also you can share data on the same machine from the main instance receiving the data feed: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
