Date/Time: Sun, 04 Oct 2026 13:19:34 +0000
question ??
View Count: 811
| [2020-03-02 15:17:22] |
| aurel88 - Posts: 8 |
Par contre j'ai quelques question, c'est vrai que vous n'allez pas accepter le flux rithmique? et pourquoi le logiciel Sierra chart depuis la mise à jour a 64 bits pose beaucoup de probleme de graphique?
| [2020-03-02 18:50:43] |
| John - SC Support - Posts: 48095 |
From Google Translate: By cons I have a few questions, is it true that you will not accept the rithmic flow? and why the Sierra chart software since the update to 64 bits poses a lot of graphics problem?
| [2020-03-02 19:02:28] |
Yes we have discontinued support for Rithmic. And the 32-bit version of Sierra Chart is still supported. It is installed and you can run it using the shortcut on your desktop. The one without _64 in the name.
