Date/Time: Sun, 04 Oct 2026 13:19:34 +0000
Not enabled to use FIX connection
View Count: 933
[2020-03-02 13:08:54]
User638002 - Posts: 2
Hello! I cannot enable to use FIX connection, only WEBAPi.I receive such messages... https://gyazo.com/6d04ce6bd9cbff72a9b4974dee95733d How to connect? Can you help me? Best regards.
[2020-03-02 18:51:54]
Update Sierra Chart to the current version:
In the case of when you want to use CQG, you need to use the CQG Web API only. Contact your broker for help with this if needed.
