Date/Time: Sun, 04 Oct 2026 13:19:34 +0000
Data feed Trading Technology
View Count: 761
| [2020-03-02 12:55:11] |
| User97684 - Posts: 136 |
Hi, If I use the Denali + Sierra + TT routing solution for trading on my Sierra platform, can I use same TT data feed to trade on another platform like Bookmap? Many thanks |
| [2020-03-02 18:02:16] |
No you cannot because this is not supported by bookmap. And also the data feed is not from TT. Sierra Chart does not support the TT data feed. Sierra Chart only supports TT order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 18:02:25
