Date/Time: Sun, 04 Oct 2026 13:20:01 +0000
Trading DOM Centering Issue
View Count: 831
| [2020-03-02 06:52:25] |
| User831766 - Posts: 7 |
After reading Documentation, I am unable to find a solution to the problem of the DOM auto-centering on the last price (this is correct per my settings), then within seconds, re-centering MUCH higher between a seemingly arbitrary Ask and Bid Background. The screenshot below happened to catch the DOM centering on this Ask and Bid Background region (this is the same color area as set within Graphic Settings - Global -> Trade Dom Ask Background and Trade Dom Bid Background). The DOM is behaving as though the resting state of the bid ask is about 10 points higher... very strange. Please help! Thank you! http://www.sierrachart.com/image.php?Image=1583130888624.png |
| [2020-03-03 08:18:54] |
This really does not make sense. We have not seen this before. We want you to go to Window >> Current Quote Window to see the bid and ask prices and when you see this again provide an image again, showing the Current Quote Window with the Trading DOM active so we can see what the bid and ask prices are at the time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-03-03 16:30:31] |
The following day (Monday), the issue did not occur again. If it does, I will provide an image with Current Quote Window as requested above. Thank you
