Date/Time: Sun, 04 Oct 2026 13:19:07 +0000
only want one trade per bar, not just one signal per bar.
View Count: 786
| [2020-03-01 01:44:41] |
| User199727 - Posts: 10 |
I try to do automatic trading using spreadsheet for trading, the problem I have is, sometimes, on one signal bar, it has more entries. for example. on one signal bar, I only want to entry 2 contracts, but during the period of the bar, price up and down, give more signals and the system entry more order at the same bar. at last I got 6 contracts. but I only want to entry one order, I try to set only one signal per bar, but that does not work. how to deal with this problem? thanks
| [2020-03-02 18:00:43] |
There really should not be a problem with this if the proper Input is set to True. Here is the relevant documentation: Spreadsheet Systems, Alerts and Automated Trading: Alert/Signal Only Once per Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 18:00:56
