Date/Time: Sun, 04 Oct 2026 12:14:35 +0000
intraday update list - interactive brokers
View Count: 822
| [2020-02-26 03:17:54] |
| User392279 - Posts: 67 |
Hi, my symbol format is like this. MES-202003-GLOBEX-USD so to add it to intraday update list, should it be MES-202003-GLOBEX-USD|MDD or something else? thanks |
| [2020-02-26 12:39:06] |
No just add the symbol as MES-202003-GLOBEX-USD and instead enable Record Market Depth Data in the Symbol Settings: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
