Date/Time: Thu, 20 Aug 2026 06:04:26 +0000
Interactive Broker not enabled on this package. How do I enable this?
View Count: 1282
[2020-02-14 15:41:41]
User339484 - Posts: 71
I trade Futures using Amp - Denali feed.
I want to also be able to trade Options with Interactive Broker on the platform, but it says that is not enabled.
How do I do this and does it cost anything?
Thanks!
[2020-02-14 16:03:51]
To do this you would need a Direct Account with Sierra Chart, rather than using the one that was provided through AMP. Refer to the information here:
Direct Sierra Chart Account
Then you would need to have 2 installations of Sierra Chart. One that would connect to your AMP account and the other that would connect to Interactive Brokers. Refer to the information here for how to do this:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
