Date/Time: Sun, 04 Oct 2026 10:18:34 +0000
All Symbols Have Dissapeared
View Count: 796
| [2020-02-14 01:22:29] |
| lmay1399 - Posts: 1 |
There are no symbols listed at all when I click on 'find symbols' or try to switch symbols under chart settings. Any ideas on why this is happening?
| [2020-02-14 03:31:56] |
This issue is now resolved. If you are missing symbols in File >> Find Symbol follow the procedure below: Follow the instructions here to update the Symbol Settings:
Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
