Date/Time: Sun, 01 Nov 2026 20:02:04 +0000
Option Chain
View Count: 2231
| [2014-01-04 20:01:49] |
| User22591 - Posts: 133 |
Sir/Madam: I did not think I was asking you for support for Option Chain: I was simple asking a question on something that I would think you should have some knowledge on. My intent is to use your platform for trading, utilizing IB data. Should you not know if the information is imported to your platform along with other data if so how or where can it be accessed or otherwise. If it is or it is not I would think a suggestion or referral could be offered. Winston Peak |
| [2014-01-04 20:58:34] |
Sierra Chart does not support option chains from Interactive Brokers. We really do not understand what you are asking about here.
| [2014-11-11 03:34:34] |
| madra - Posts: 109 |
is it possible to trade option spreads in sierra charts? using IB
| [2014-11-11 07:57:32] |
No, this is not supported.
