Date/Time: Tue, 07 May 2024 08:57:43 +0000
PLEASE HELP!... STOP ORDERS NOT WORKING PROPERLY
View Count: 2366
[2020-10-13 15:32:26] |
User103448 - Posts: 69 |
According to trading log, price was at 111.000, when i placed the order. But market was closed. it was 1 hr before market opening. Im not quite sure what you mean, could explain it another way ? Thanks so far! Date Time Of Last Edit: 2020-10-13 15:33:29
[2020-10-13 17:06:03] |
rahul - Posts: 160 |
What might have happened is the open was higher than the price for a brief second which might have caused issues with the stop order. I recommend placing stop order when market opens instead, else go with the "error check" approach I mentioned. Logic: If symbol price < 111.025 then buy stop order. Get the order ID of this buy stop order (refer to Sierra Chart documentation). If symbol price > 111.025 and buy stop order ID is not filled, then cancel order and execute market order instead. |
[2020-10-23 18:47:05] |
How can i check if an order is placed server side or client side ? appreciating quick answer before weekend. best regards! Luigi |
[2020-10-23 19:13:14] |
If the Status of the order is "Held" it would be client-side. You can check the status in the Trade Orders Window: Trading Information Windows: Trade Orders Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-23 20:05:03] |
thanks, order status for all open stops are "open". have a good weekend. |
