Date/Time: Fri, 06 Nov 2026 09:06:05 +0000
Data Feed solution for SC and Bookmap
View Count: 5205
[2020-01-26 12:46:22]
User118500 - Posts: 6
I am in need of a data provider for both SC and Bookmap. I would like to have one solution that feeds both. It is my understanding right now that Denali Feed is not an option for Bookmap? Is this correct? If so is there future plans for such a solution? Time frame if there is?
With regards to the Denali feed. Is it true Tick by Tick data? Or is it aggregated? Where are the servers located? If more then one do you have a choice on which one you connect too? (Chicago vs Europe etc)
Thanks in advance for any insight you might be able to share.
[2020-01-26 21:39:55]
seandunaway - Posts: 398
Did you know you can replicate Bookmap's feature set with SC?
Date Time Of Last Edit: 2020-02-13 14:28:58
[2020-01-26 22:39:15]
I am aware of what SC offers in regards to Heatmap and Large Volume Indicator. It is similar in nature but is not the same in my mind.
[2020-01-27 06:27:04]
Sierra_Chart Engineering - Posts: 25390
The Denali feed cannot be used with Bookmap because they do not want to support it, so there will never be a solution for that.
Yes. The servers are in Chicago.
[2021-11-04 18:07:58]
inapoli74 - Posts: 3
Hi there is it still the case no possible to connect SC to BookMap via the Denali feed?
Regards
[2021-11-04 18:20:41]
It is still the case that the Denali Exchange Data Feed only works with Sierra Chart.
[2021-11-05 07:00:18]
Tonkadad - Posts: 235
Take a look at this video. I am not really familiar with BookMap but this SC user has created some really interesting charts.
https://www.youtube.com/watch?v=AW1GJaDlQwY
[2021-11-18 19:49:13]
User431006 - Posts: 4
With Sierra Chart Teton Futures Order Routing:
Can Other Programs Use the Trading Connection and Data Feed?
Yes, they can use the DTC Protocol and connect to the DTC Server in Sierra Chart.
Please clarify this...
You not allow 3rd party applications to accessing exchange data through DTC server.
[2021-11-18 23:28:57]
Yes other programs can use the Trading connection to the Teton Futures order routing service through the DTC protocol server, but not the market data because this is not allowed by the CME with the arrangement we have with them. This is not up to us. It was up to us, there would be absolutely no restrictions whatsoever.
Date Time Of Last Edit: 2021-11-18 23:29:15
